Militec-1 ou LL-50. Ganho na performance e proteção.
Re: Militec-1 ou LL-50. Ganho na performance e proteção.
Mensagempor brunosouzapn » 10 Set 2016, 06:19
brunosouzapn
Mensagempor choppinho » 10 Set 2016, 10:41
choppinho
Mensagempor brunosouzapn » 10 Set 2016, 14:51
brunosouzapn
Mensagempor ReiNato » 10 Set 2016, 17:12
MILITEC-1 Did Not Pass Any Tests and Evaluations as a Small Arms Cleaner, Lubricant, and Preservative
MILITEC-1 Did Not Pass Any Tests and Evaluations as a Metal Conditioner or a General Purpose Lubricant
MILITEC-1 Demonstrated Some Positive Attributes as a Lubricant Additive in Two Early Tests and Evaluations, but Did Not Pass a Subsequent Test and Evaluation
ReiNato
Mensagempor brunosouzapn » 11 Set 2016, 00:05
brunosouzapn
Mensagempor André Razgriz » 23 Set 2016, 08:40
Usei na minha E36 eu senti o giro subir um pouco mais suave, na próxima troca de óleo usarei novamente, mas estou na duvida se uso Militec ou o novo condicionador de metais da Bardhal...
''O Chassis deve ser mais rápido que o motor''
BMW 328i E36 1996 ( alemã ) ex
BMW 328is E36 1996 Coupe Manual (alemã)
André Razgriz
Registrado em: 12 Set 2013, 15:29
Mensagempor loudenvier » 25 Set 2016, 17:07
Mensagempor brunosouzapn » 25 Set 2016, 18:24
Segundo o fabricante:
Just as important as knowing what’s in MILITEC-1® is knowing what isn’t. MILITEC-1® does not contain chlorinated paraffins, PTFE, fluorine, solvents, carrier oils, viscosity enhancers, metals, molybdenum disulfide, zinc, sulfur, graphite powders or other solids. It’s also important to realize that MILITEC-1® is non-hazardous, non-toxic, and non-combustible. It is so safe that MILITEC-1® was even approved environmentally by the U.S. Navy Medical Command for use aboard nuclear-powered submarines.
fonte:http://www.militec-1.com/militec1-defined.html
brunosouzapn
Mensagempor loudenvier » 28 Set 2016, 01:13
Mensagempor brunosouzapn » 28 Set 2016, 09:27
brunosouzapn
Usuários navegando neste fórum: AdsBot [Google] e 27 visitantes
