Varias peças E34 525i 2/94
Mensagempor leohermano » 24 Out 2015, 15:12
Amigos,
Infelizmente tive que me desfazer do meu carrro antes de implementar as melhorias planejadas. Comprei várias peças na Pelican Parts, entre 2011 e 2102 que não foram utilizadas e que estão na relação abaixo, com os respectivos preços.
Os interessados poderão entrar em contato por aqui, pelo email leohermano@gmail.com, ou pelo 21 983850070.
Também tenho uma tampa de porta malas na cor preta, que comprei pelo ML e não usei.
Obrigado.
07-11-9-920-067 Fillister Head With Washer M6X16
07-11-9-913-664 Hex Bolt - Size M8 x 30
07-12-9-952-102 Hose Clamp,
 Brand: Genuine BMW
09-2043-004-M30 Transmission Service Kit, Automatic Transmission A4S310R (GM 4L30-E), Contains: (1) Filter (2) Gaskets (28) Pan Bolts
11-12-1-312-173 Spark Plug Hole Gasket (3 per car, sold individually), M5 (1991-93),
 Brand: Elring Klinger
11-12-1-730-352 Rubber Grommet for Valve Cover, Various Applications,
11-12-1-730-356 Upper Valve Cover Mount (2 per car, sold individually) 525i Sedan/Touring (With M50 Engine)(1991-95), Each
 Brand: Febi
11-12-1-740-396-BOE Genuine BMW Part: Connector
11-12-9-064-467 Head Gasket Set
11-36-1-436-071-BOE Genuine BMW Part: Bracket
11-42-1-730-389-M45 Oil Filter Kit, Contains: (1) Filter Cartridge, (1) Filter Housing Seal, (1) Rubber O-Ring, (1) Drain Plug Seal, (1) Metal Seal Ring,
 Brand: Hengst
11-42-1-730-389-M63 Oil Filter Kit, E34 525i M50, 525i Touring
 Brand: Mann
11-42-1-730-389-M67 Oil Filter Kit, E34 525i M50, 525i Touring
 Brand: Mahle Filter
11-531-738-054 Heater Hose
11-62-1-728-983-M17 Exhaust Manifold Gasket (3 per car, sold individually), 525i (1991-95) Sedan with M50 Engine (E34),
 Brand: Victor Reinz
12-1-317-03359
12141726-066 Crankshaft Sensor
12-141-738-667 Knock Sensor
12-31-7-677-914-M9 Adjusting Nut, Toothed Nut for Adjusting Alternator Belt, Power Steering Belt, and A/C Belt, E34 525i, Brand: Genuine BMW
12-52-1-276-010 Danper Ring
13-0-837-2559496 Anti Sequeal Pad
13-32-1-270-038-M67 Fuel Filter -
 Brand: Mahle Filter
13-41-1738-185 Air Hose
13-541-738-622 Water Hose - Thermostat to Head,
16-11-1-177-874-BOE Genuine BMW Part: Hose,
 Brand: Genuine BMW
16-11-1-181-142-M9 Locking Ring for in Tank Fuel Pump & Sending Unit, E36 3 Series (All), Z3 (All), E31 8 Series (All) -
 Brand: Genuine BMW
16-12-1-177-108 Hose,
 Brand: Genuine BMW
16-12-1-178-632 Bracket Fuel Strainer,
 Brand: Genuine BMW
16-12-1-178-643-BOE Genuine BMW Part: Damper Ring
16-12-1-180-409-BOE Genuine BMW Part: Fuel Hose,
 Brand: Genuine BMW
16-13-1-176-747-M58 Plastic Nut (6 mm), as needed -
 Brand: OEM
16-13-1-179-180-BOE Genuine BMW Part: Hose,
 Brand: Genuine BMW
17-10-1-728-766-BOE Genuine BMW Part: Covering Lower L=483MM, 525i (1991-95) Sedan with M50 Engine (E34),
 Brand: Genuine BMW
17-11-1-178-412-BOE Rubber Insulator for Lower Radiator Mount, 525i (1991-95) Sedan with M50 Engine (E34),
 Brand: Genuine BMW
17-11-1-709-333-M9 Radiator Mounting Bracket, Lower Right, (Plastic), 525i (1991-95) Sedan with M50 Engine (E34),
 Brand: Genuine BMW
17-11-1-712-347-M9 Radiator Mounting Bracket, Lower Left, (Plastic), 525i (1991-95) Sedan with M50 Engine (E34),
 Brand: Genuine BMW
17-11-1-712-660-BOE Radiator Mounting Bracket, Upper Plastic2 Per Car, 525i (1991-95) Sedan with M50 Engine (E34),
 Brand: Genuine BMW
17-11-1-712-963-M58 Rivet for Fan Shroud, Auxilliary Fan Housing, and some Interior Trim Panels, 525i (1991-95) Sedan with M50 Engine (E34),
 Brand: O.E.M.
17-11-1-712-966-M9 O-Ring for Expansion Tank Upper (14.5mm), 525i (1991-95) Sedan with M50 Engine (E34),
 Brand: Genuine BMW
17-11-1-719-321-BOE Genuine BMW Part: Profile Gasket L=483MM, 525i (1991-95) Sedan with M50 Engine (E34),
 Brand: Genuine BMW
17-20-1-719-414-BOE Rubber Insulator for Upper Radiator Mount, 525i (1991-95) Sedan with M50 Engine (E34),
 Brand: Genuine BMW
17-21-1-712-965-M9 O-Ring for Expansion Tank Lower, 525i (1991-95) Sedan with M50 Engine (E34),
 Brand: Genuine BMW
18-11-1-175-311-M131 Exhaust Seal Ring, 47mm, 525i (1991-95) Sedan with M50 Engine (E34),
 Brand: Fischer & Plath
18-11-1-723-540-BOE Gasket Ring Asbesto free 50MM,
 Brand: Genuine BMW
18-30-7-536-424-M131 Clamping Ring, to Join Center and Rear Mufflers Together, 49mm 525i Sedan/Touring (With M50 Engine, 1991-95),
31-331-124-449 Foam Bump Stop for Strut/Shock,
34-35-1-179-820-M163 Brake Pad Sensor, For Front or Rear (2 per car, sold individually) BMW E34 5 Series, All, Each
 Brand: PEX
36-13-6-768-641-M9 Wheel Center Cap, 4 Per Car, 525i (With M20 Engine)(1989-90), 525i/Touring (With M50 Engine)(1991-95), Each -
 Brand: Genuine BMW
51-11-1-934-336-M9 Impact Strip, Front Bumper, Right, E34 5 Series, All, Each,
 Brand: Genuine BMW
51-16-1-938-352-M9 7 BASE, 525i (1991-95) Sedan Automatic Transmission, with M50 Engine (E34),
 Brand: Genuine BMW
51-23-1-908-430-M9 Clip for Hood Shocks, 525i (1991-95) Sedan with M50 Engine (E34),
 Brand: Genuine BMW
51-24-8-110-327-BOE Trunk Lid Shock 2 per car sold individually E34 5 Series, All Except Touring Models, Each 410N, 525i (1991-95) Sedan with M50 Engine (E34),
Brand: Genuine BMW
51-41-1-973-500-M58 Panel Clips, as needed, Each
 Brand: OEM
51-47-8-140-118-BOE Genuine BMW Part: Rotary Latch 18 Mm,
 Brand: Genuine BMW
51-49-1-946-195-BOE Genuine BMW Part: Push-Button
51-71-1-944-904-BOE Genuine BMW Part: Clamp
51-71-1-946-434-M9 8-COVER
51-71-1-958-025-BOE Genuine BMW Part: Plastic Nut
54-12-1-944-649-BOE Sunroof Seal, BMW E34 5 Series, All, Each,
 Brand: Genuine BMW
61-35-8-350-566-M9 Multi Purpose Relay (6-Prong) Pine Green
 Brand: Genuine BMW
61-36-1-729-004-M9 Relay for Motronic, 5-Prong (White), BMW E34 5 Series, All, As Needed, Each
 Brand: Genuine BMW
61-61-8-361-475-M78 Wiper Blade, 22in, Left, E34 525i M50 (from 9/90), 535i (from 9/90), M5 (from 9/90), 530i V8, 540i, 525i Touring, 530i Touring, Each
 Brand: SWF
63-21-7-160-786-M97 Bulb for Ellipsoid Type Low Beam Headlights (9006) 12V/55W, BMW E34 525i, 525i M50, 535i, M5, 530i V8 (through 12/93), 540i (through 12/93), Each,
 Brand: Osram-Sylvania
64-11-1-388-000-BOE Genuine BMW Part: Cover
64-12-1-379-221-BOE Push-In Expanding Nut, Various Applications, Each
64-211-384-712 Heater Hose - Water Valve to Radiator
64-211-384-746 Heater Hose - Inlet to Additional Water Pump Inlet 1,
64-211-384-763 Heater Hose - Water Valve to Additional Water Pump Inlet 2,
64-211-391-387 Heater Hose, Intake from Back of Head
64-211-391-766 Heater Hose - Heater Core to Water Valve,
81-22-1-468-879-M210 Pentosin CHF 7.1 - Power Steering Fluid (1 liter)
 Brand: Pentosin
82-59-9-402-197-BOE Genuine BMW Part: Lock 21,5mm,
 Brand: Genuine BMW
BR-AS-008 Anti-Squeal Pad Inserts, set of eight (full car)
PEL-SW50189 Redline Water Wetter, 12 oz. bottle
Leo
E34 525i M50 alemã
leohermano
Registrado em: 03 Jan 2012, 13:51
Voltar para Veículos BMW
Usuários navegando neste fórum: Google [Bot] e 2 visitantes
